3 Question about 8800 GTX/Tunic Tower & Casing !!!
Webb
The Evga 8800 GTX has 2 power supply plugs in the back,they both needs to be plugged into the PSU ?
The 120 Tunic Tower fans is almost impossible the hear,because my case has 3-80mm and 2-20mm,So I will never know if the Tunic fan is working properly,how can I found out before my CPU is cooked ?
Well mt case order from NE came with the front panel broken,well the screws that hold the casing in the metal frame is broken,so to avoid the hassle of returning and all I decided to keep it,question ?
I will drill a hole in the plastic casing and metal frame to hold them together 4 all total.Is it safe to put metal screws ? I'm not worry about looks the case will be on the floor.
Thank you
1. Yes both need to be plugged in
2. Check your temperatures in BIOS
3. Metal screws are fine
Yes, both connectors need to be plugged in from the PSU.
Speedfan will monitor the Tuniq's fan's RPMs along with your core temps. Don't worry, the CPU is designed to shutdown before any damage can occure... and if not, its got a 3yr warranty! ;)
Which case? Call Newegg or the manufacturer, they'll probably just send you a new front panel instead.
You paid for a new case, don't settle for anything less. Get that front panel from newegg or the case manufacturer.
