I decided to wait and see what Conroe will do, sooo I decided to either The reason I want to stay socket 478 is because I just recently bought a AIW 9800PRO agp and want to keep it, plus the 875P is a great Overclocker and since i'm going to peltier t A) spend money on a abit IC7-max 3 motherboard and toss my 2.66ghz 533mhz fsb in there and thermaleletrify the cpu (226w peltier), but the question is How high could i reach with this processor? - $200 I know theres no way i'd reach 200mhz fsb * 20multiplier = 4ghz perhaps 3.2-3.5ghz max?? CPU will be bottleneck as IC7 does 200mhz standard or B) spend $240 and get a p4 3.2E 800mhz fsb w/ hyperthreading prescott, 1mb cache overclock to 3.5ghz = 220mhz FSB (socket 478) - $340 (IC7+3.2) How high would I be able to overclock it???? or C) spend $258 and get a Intel Pentium D 920 Presler 800MHz FSB LGA 775 Dual Core - $65 ASUS P5VD1-X Socket T (LGA 775) VIA PT880 Ultra total $321 but I have no idea how well this board will perform ------------------------------------------------------------------------- each option has its own strength and weakness option 1: Keeping current CPU enables me to spend more on a much better motherboard and hope the CPU will scale high enough Option 2: spend alot on the CPU but get a base motherboard and hope the motherboard will allow me to OC high enough Option 3: spend alot on CPU but get a motherboard with a VIA chipset not know how well it'll overclock or its stability, but wit the ofset of a Dual core CPU _____________________________________________ I have to get a board with AgP 8X hence anything after 875P is PCI-Express I've had this system for what 2years i think.... and next upgrade after this wont be until 2007+ just need something to help get me by, dont know how much longer this cpu can hold out running 63+ processes, encoding, ripping, burning, etc all at once. system is extremely slow. very multi-tasker
I wouldn't bother trying to find a Max3, look for a IC7-G instead. The IC7-Max3 doesn't have that much of an overclocking advantage over the IC7 and IC7-G. Look around and see if you can find something that is selling a P4C or P4E that allready has a good idea of how good it will overclock. Your 2.6B won't overclock very well even on a IC7. http://www.hardforum.com/showthread.php?p=1029094578#post1029094578 Thats a pretty nice price for his 2.4C, being that he's running at 3.2ghz on stock voltage/cooling you might be able to hit 3.4+ghz with it.
Get the 920 and the via board, down the line you can sell via board and upgrade to a new board with better features like SLI PCI-express, but really, the dual-core will come into play for all the things you do, where as the 478 doesn't cut it with all that you do. Also i've seen a few people hitting 4ghz on air with the 920, a huge plus when its dual-core!
option A - probably won't overclock well, bad choice option B - will probably hit 4Ghz with Peltier. option C - why not spend and extra $30 for a nice Asus- Intel chipset mobo (see option E) option D - get a Pentium D 805 ($141) + Asus 945 mobo ($96) and probably overclock it to 3.7Ghz+ (CHEAP & FAST) option E - get a 920 ($260) + Asus 945 ($96) and probably overclock to 4Ghz
Also, an Asus board with a ct-479 adapter would work. Asus board: http://www.newegg.com/Product/Product.asp?Item=N82E16813131484 Ct-479 adapter: http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=372304 Cpu: http://www.newegg.com/Product/Product.asp?Item=N82E16819111170 I have this exact combo running 2.65G on air @1.35Vcc This thing is FAST! This combo has an unlocked (6-20) multi too with newest bios.
The reason those will not work is because they do not have AGP slots for his video card. While, I think Option C would work out the best for the long run, how much money can you put into a Via chipset and hope that it works. Of course I would not be counting on much O/cing at all on that platform
sorry, but a 9800Pro isn't exactly something to hold back your whole system for. If he had an X850XT PE maybe.
ok try this 3.00GHz (prescott core) OCed to 4.2Ghz under air cooling only 35c idle http://valid.x86-secret.com/show_oc?id=72181 dont really need to go all out with a peltier setup I say take option B
That's what I hated about my 9600 AIW. I got a TV wonder now. And a x800GTO. I like option "E". Also a i975x mobo is looking promissing for Conroe. Bit-Tech reported a BIOS flash will do the trick, http://www.bit-tech.net/news/2006/03/10/bridge_creek_conroe/ Not so sure myself.
get an IC7-G and a 3.2C if you can hit 300mhz on the FSB with the pelt you got 4.3ghz I might know some1 that has a p4 3.2EE and an IC7-G that they'll sell for $500. I'd love to see just how far the second fastest 32 bit proc can go.
A 3.2EE and IC7-G for $500 is high. 3.2EE are worth around $350 max. The IC7-G even complete are only worth $125ish. For that kind of money he could go dual core AMD 939 with a AGP slot.
where can u find a 3.2EE for $350? the only 3.2EE i seen was on 2 sites 1 had it for $600 and the other had it for $900 both for the socket 478
i`m good on ram mines running 2.5-4-4-7 and i got 2Gigs of it, if you do sell PM me a price i`d be able to buy after i sell my other computer i rebuilt or we can work out a trade
You can get asus p800SE mobo on 865 for cheap dual core support with AGP and DDR I. Then get 805d or 920 and overclock
Several have sold on Ebay for that amount. The 3.4EE still goes for around $500. I picked up one on the forums here for $275.
I sold my 3.4EE for $500 and my Abit IC-7 for $90. It kicked ass when I had that system. Here's a benchmark of my 3.4EE, Abit IC-7 & 6800GT: http://service.futuremark.com/compare?3dm05=1327759
you saved me alot of money now the question is what would be faster stock? overclocked? -multi-tasking, 60+ processes, rarring, extracting, dvd encoding, you name it i'm doing it :-D Asus p4p800 deluxe with 3.4ghz prescott or asus p5p800 SE with 2.8ghz smithfield (dual core) going to save the major upgrades 500+ on cpu, 200+ on mobo, etc for conroe/quad-core (when i saw those benches had to fall back) i'm hearing the 3.4E will do ~4ghz air, 4.5ghz water, 5ghz pelted would the dual core smithfield be able to keep up with that? not interms of getting that high in clock but in terms of performance?
