3 Monitors - 1 Card
Seemund
Quick question,
I currently have a BFG 8800GT w/ 2x 23" Samsung LCD Monitors.
I'm thinking about getting another 23" monitor and making it a 3-monitor setup but my Video card only has 2x DVI Ports.
Also, my motherboard only has 1x PCI 2.0 X16 slot, so SLI isn't an option.
What can I do to make this work?
Is there an easy solution other than selling my 8800GT and buying a card with more slots?
Thanks...
Do you mean you want to game on all 3 monitors, or just have 3 monitors for the desktop?
If the latter, you can just get a cheap PCI video card or something afaik.
You can add a second card without needing an SLI motherboard. If you don't have enough PCI-E you can just find a PCI video card.
