3 MBs to choose from...?
I'll vote the Infinity, I have no experience on the other boards but they all look good.
I've never used an Infinity...BUT...i have heard only good things about them...i cant recall anyone saying they have having issues etc...they seem solid, well balanced and good for OC'ers...
I wouldn't get any of those. I've heard bad things about NForce2 boards, but some people here have no problems.
Yeah I am most likely going to go with the dfi mb because it has more usb and sata slots than the abit, but than again, maybe the abit has is better in quality or sum features I dont see.. hhmm.. lol
So since you work with DFI mbs. what do u think of the onboard sound with the board I have posted? Im really into the board due to the fact it has 4 sata connections! Any advice from u would be awesume! thanks
I have never used a DFI product in my life. However, looking at the specs on that board, it's really in a totally different league than the other two.
1) I have a personal bias against Abit, so you can ignore my opinion on that board.
2) A friend of mine had that Gigabyte board. One day, while at his house, he turned his computer on and the board fried itself. Completely fucked it over. The BIOS most likely, because during post, it would go nuts and a bunch of strange letters and characters would replace the normal boot up screen. That board had dual BIOS chips, both were toast.
3) That DFI board you linked to has MCP+T. That is a good thing. That right there elevates the board above the other two you listed.
I also suggest you look at Newegg's refurbished motherboards. They have some good Leadtek boards, along with some Epox boards you might want to look at. :) Personally, I'd stick with that DFI board, though... ;)
I don't know why you think the NF2 sucks. It's been the first choice for performance minded AXP users for over a year now.
Hey thanks so much for the posts and help
Very happy with the help here
Thanks so much ’m‚³‚ñ for your info on it
Is mcp+T sumthing u can easily explain.. Not sure on it.
as always, thanks
i have Gigabyte GA-7N400 Pro2 and i just love its IDE1,2,3,4 function cuz i have like 5 hard drive in my main rig... also, its very stable... most of times, i just turn this computer on most of times... it just runs very smoothly for me... and it is fast... and its overclock ability is not too bad... i currently have my 2500+ barton around 2.3 ghz... i recommend this mobo... but both DFI and abit is amazing.... if you are going to overclock your cpu... i guess my recommendation is abit mobo....
BTW, i play UT2K3, UT2k4, battlefield, Max Payne2, NBA2k4 without any problems!!! :) good luck
infinity if your into overclocking. if your not you should be. get a mobile cpu like this and save you self ~$140 and earn yourself a better performing cpu.
as always, thanks
MCP+T is the SouthBridge. Basically, certain components, such as the onboard FireWire, onboard sound, onboard LAN, are controlled by the SouthBridge chip directly (or, more directly than otherwise). It's a bit more expensive than the alternative, MCP. In my experience, it's just a bit more stable, especially for overclocking. My onboard firewire doesn't like certan bus speeds on my mainboard that has MCP, but the board with MCP+T, strange bus speeds don't phase it. ;)
