1) What will you be doing with this PC?
Gaming (tailor made for battlefield bad company 2)
about $200 per component
3) Where do you live?
Northern california
4) What exact parts do you need for that budget?
cpu, mobo, ram, gpu
5) If reusing any parts, what parts will you be reusing?
DVD, PSU , anything else I can
6) Will you be overclocking?
no
1680x1050
Mid Febuary
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support?
DX11 for BBC2
10) Do you already have a legit and reusable/transferable OS key/license?
no I need to buy W7 for dx11
Look at my sig, its getting old. I built it in 2005, when BF2 came out. Since then, I upgraded to dual core, psu , gpu and some odds and ends. Its time to retire it for the next generation BBC2.
I want to go with AMD
1st setup: use my midtower and do a cpu,ram, mobo, swap + gpu swap
amd 955
Asus M4A785TD-M EVO
gskill 2gb x2 ddr 3
xfx 5770
Pros: least expensive, most upgradeable, recycles most parts
Con: least mobile
2nd setup: shuttle case
SA76G2
amd 955
gskill 2gb x2 ddr 3
xfx 5770
pros: mobile,small, light
cons: can't reuse a lot of parts, need new psu & case, can't upgrade to huge cards later.
3rd setup:
Hp Envy 15 laptop
pros: The most mobile and most powerfull
cons: most expensive, no upgrades, no DX11 card
A while back when I built my rig in my sig for BF2, I carried it around to big LANS and small lans at friends houses. I don't plan on doing too many lans but will moving my rig between my mom's house and my GF's appt. I fucking hate carring shit all over the place, especially with stairs. I never had a laptop before I and think it would be cool to have it pull double duty as desktop replacement/lan rig. I shuttle would be good as long as I could get a carry case for it. I will get lazy with the midtower and just be caught without a rig some days.
Northern california
cpu, mobo, ram, gpu
no
1680x1050
Mid Febuary
DX11 for BBC2
amd 955
Asus M4A785TD-M EVO
gskill 2gb x2 ddr 3
xfx 5770
Con: least mobile
SA76G2
amd 955
gskill 2gb x2 ddr 3
xfx 5770
3rd setup:
Hp Envy 15 laptop
