3 dead systems, perhaps you can fix one?
ScHpAnKy
Because I sure can't.
I have this system...
An Athlon XP 3200+ in a shuttle SN41G2B (nForce 2 chipset) with 1024MB of Corsair DDR400, a 40GB Seagate hardrive and a GeForce FX5600 Personal Cinema.
Now, this system hasn't given me much headache since I've recieved it back from RMA (after the first two mysteriously were dead on arrival) but just recently all of my systems died (for the exception of this server, bless it's little p3 heart) almost synchronously (within 2 days of each other) and I cannot make heads or tails as to why!
The other two I'm just going to RMA every single part, but I'd like to find out what exactly is wrong with my shuttle? It worked fine for the longest time, but after I formatted the drive and reinstalled windows applications kept crashing in windows. I couldn't even get drivers to install because they would have CRC errors.
I did all of the following:
Tried different video cards (onboard, FX, 6800)
Swapped ram (went from corsair to GeiL ddr400 to GeIL DDR500 to corsair C2 DDR333)
swapped hardrives (Seagate 40 to Seagate 200)
reset the bios several times
formatted/reinstalled windows several times
removed pci cards to prevent IRQ conflicts
tried different versions of nForce2/GeForce drivers
wtf do I do?
It boots into windows fine, it seems, now... but as soon as I install drivers I get blue screens all the time.
which version of nf2 was it? i know the first versions didnt support fsb4000, so that could be it
it ran it at XP3200 for quite some time, I know that's certainly not the reason, thanks for the input, at least some people are making the attempt of reading this thread :(
Sounds like a possible system board problem. Once you install the drivers, you say it blue screens. Generic drivers are ok because they use the most conservative settings and don't access any specific features, but when you install hardware-specific drivers, it crashes, correct?
You've tried everything else, by process of elimination it sounds like mobo.
I've had the worst time with power suppies getting wierd and killing mothewrboards in this house because of old wiring and fluctuating voltage as well as bad equipment grounds. This house is old 2 wire construction. Dirty power might be your problem.
Considering it's a functional brand new electrical system in my house, I doubt it's from the AC lines, but now I am considering the PSU to be one of the factors... thanks for your input
Right, you've just assured my current idea, I think it's time to just ship out all my parts for RMA :(
well if three, brand new RMA'd boards have had the same problem, id guess the PSU. what kind is it? how old is it? you got a spare lyin around?
edit: you know when i read shuttle, i thought shuttle mobo... have you thought about heat? those shuttle barebones are tiny.. also if its a barebones, those shuttle psu's are pretty damn high quality so i might rule that one out... but just to make sure test all the parts on a diff board, or just connect a diff psu for a test...
Each one of the systems has a different and seperate psu
well are they in the tiny shuttle cases? the ones taht have heatpipe coolers on the cpu and are about a third of the size of an atx mid tower case? or did you just buy the motherboard and put it in a case youreslf?
