3 Dead Motherboards :( :( :(
gkg101
Windows XP sp2 home
Opteron 185 dual core
Antec SmartPower 2.0 500w>>>>>>>>>Corsair HX620w
A8N - E >>>>>>>>>>>A8N -SLI-SE
1XEVGA 8800GTS 320>>>>>>>>>>>>2XEVGA 8800GTS 320
Corsair TwinX pc3200 400ddr ram
Audigy Se
Samsung 226bw
First, Thanks to all who've helped me so far.
This a long but exciting story :rolleyes: which can be googled/searched under gkg101.
Basically my original system is listed to the left of the chevrons. What prompted a change was when my system failed. The culprit appeared to motherboard failure of type which produces 1 long and 2 short beeps (VGA Adapter?). Subsequent power ups yielded zero beeps with no components installed except for fans and cpu. Asus sent me an RMA, which was a free upgrade of an A8N-SLI:D. But this new board AND a subsequent new board that Asus sent me all failed to produce any beeps even with just cpu/fans. :confused:. I even swapped in an Athlon 4000 single core and still nothing. So now three boards in my chassis that don't beep. I know my PC speaker still works --the only time I got it to beep was when I had one of my 8800gts in and disconnected the monitor cable -- I got a long loud continuous beep.
I'm a real newbie when it comes to this. Is anyone not puzzled? Could the new PSU be to blame? Do I have a short in my chassis? Or is a bad string of Asus motherboards?
Edit: I was reading another post and maybe I'm forgetting to hook something up to this four pin connector near the primary PCI slot, called 'EZ_PLUG'?? Could that be it?
try adding in a different graphics card, judging by the fans spinning but no post makes me think it is similar to a problem i have. my mobo just doesnt like 8series it wont post no matter what, the card is fine and the mobo is fine but it may not like the 8800. so just try swapping in someone elses card momentarily to see if that works. best of luck.
Completely disassemble the system. Place the mainboard on a non-conductive surface, then install the minimum components needed to make the system boot, being the CPU, RAM (one stick!) and videocard. Hook up a monitor to the GPU and add a PSU. Bonus points for using known working parts.
The goal is to get this minimal configuration working and stable. Reset the CMOS before you begin and boot the system. If it doesn't work, replace parts starting with the low-level components like the PSU and CPU until you get at least some error beeps/messages. Based on this swap out other parts until you get it working. If replacing parts this way aside from the mainboard itself doesn't result in a working system, the culprit is probably the mainboard.
Good luck.
I had a similar problem a while back that I tracked down to my boot SATA hard drive.
The fans would spin for a second or two and quit. Thought it was the mainboard or power supply but the system would start up fine if that one SATA drive wasn't connected.
Good luck.
I would try that too. Just use only the essentials when you remove the board. Plug in only the CPU, RAM, video card, and power supply. Boot up and if you get into bios, shut down and start adding hard drives and such one by one. If you don't get a post into bios, remove your RAM and plug in your motherboard speaker (if it isn't integrated already). Turn the system on without RAM. If you get a 3-beep error from the speaker, your CPU works and it's most likely your RAM. Try each ram 1 stick at a time on the two banks closest to the CPU socket (since they're usually default) and see which one posts and which one doesnt to isolate the problem to one part.
Thanks all. I probably should have mentioned before the post that I destroyed my Opteron 185 during my testing. After freeing the clips, I was lifting up the heat-sin/fan from the CPU and the cpu came out of socket prematurely along with the heat-sink/fan. Some of the pins got quite bent. Can I fix that? OMG. I have this basic theory that I did something really stupid, but I haven't developed that theory much.
Anyway after the incident, I was able to fit in my old 4000 single core in the slot to see if that would at least produce a beep from my working PC speaker. But still no beeps. Now I suppose I should take all your advice and do some testing (hoping nothing further was damaged which would obscure everything).
But I was under the impression that a motherboard should produce some kind of beep from a pc speaker with just the CPU and PSU installed. I've heard nothing in every case and that's with 3 different boards - (my original and the 2 RMA's that ASUS has sent me). My PC speaker works (heard it when, at some point during trouble shooting, I powered on with a video card installed sans connection to monitor- a long loud beep) I don't see the point in trying to boot to an operating system or bios if the low level functions don't at least, come alive. That's why I tried to swap in my old CPU. Now I'm thinking something more basic like a short in the chassis. Or maybe somethings not hooked up? The same conditions were in effect with 3 different PSU tried.
Anyway wrote some of this to ASUS RMA support. I'll call them tomorrow and give an update. But to be honest, I'm thinking of dumping the whole set up and buying one of those MB/CPU/RAM combos that they sell at TIGER direct. But If anyone has any advice concerning all of this stuff? I'm pain in ass, sorry. But even if I do buy a new setup, I wanna know what I did wrong
Oh and if anyone is still reading this, anyone know where I can get an Opteron 185 dirt cheap? Also how would one attach a pc speaker to a motherboard, if it's out of the case. I thinking one would have to solder.
If the pins of a CPU aren't bend too severely you can usually bend them back with the proper care and patience. Also not all pins on a CPU are used or are redundant (ground pins especially), so even a broken pin isn't necessary a death sentence.
Most mainboards have a PC speaker onboard. Usually you can also attach an external PC speaker using the front-panel headers (where you connect the power switch and such).
Elledan, After a couple of tries I was able to nudge the pins so that my opteron 185 cpu can once again fit in the socket flush so that the CPU fan turns but am unsure if any damage happened. I guess it's time for more trial and error. Wondering what I did wrong in the first place to bend the pins. Could it have been the thermal paste being in a state that made it too sticky?
Go get you a .5mm mechanical pencil. The barrel will fit over pins perfectly and you can use it to bend them back if they are bent. Been a trick I have used for years that works great. That said, I NEVER build a system in a box without testing it on an open bench first. Takes a little more time, but saves headaches in the long run.
You mentioned clearing the cmos, but try going a step further.
Unplug everything, hit the power button to drain off any residual power from the PSU.
Pop out the CMOS battery, set the clear CMOS jumper and let it sit for a few minutes. Put the jumper back, replace battery, hook everything back up and try it again..
I've had a few systems this revived. Every time, it was a similar issue. System would power on, fans and drives would spin up, but no video sync and no post beeps.
HTH
[EDIT] Kyle's mechanical pencil trick has saved me on more then one occasion. Also after you release the HSF clips, twist the HSF back and fourth several times before lifting up. I've yanked a cpu out of the socket while the latch was still down too. It only takes once to learn that lesson. :)
Well my Opteron CPU now sits flush in the socket with the fan turning. I'm wondering if it is indeed fixed or just seems fixed. (I didn't use the mechanical pencil technique but the pins do seem less bent now, upon visual examination)
EDIT oh thanks for all the tips. I'll proceed on them sometime today or tonight. First, I'll call Asus tech support today as they've elevated the support level. Thanks all
Anytime I build/diagnose a system I bench it. Eliminates the hassle of reaching inside a case and fiddling around.
make sure there is nothing shorting out the board (touching the mobo to the case).
It's a good rule of thumb to plug in EVERY power adaptor on the mainboard. 24 pin, 4/8 pin, molex. ;)
well, when one tests the mb outside the case, how would one power on and off. Will it be 'on' by default, using the PSU switch to turn on and off?
If I have this correct, you just keep booting it with no monitor hooked up waiting for beeps even with the new mainboard?
Have you tried having a graphics card installed and connected to a monitor to see if the computer is posting?
I have a funny feeling that this whole time the pc is just sitting at a state of "No Hard Disk" found since none is connected.
I've tried to boot with everything attached and got no beeps. I was advised to remove all components except PSU and CPU and see if I get a beep pattern. I've got none so far, even after trying 2 RMA'd boards, and the original which failed last month.
You short the pins your power switch plugs in to with a screwdriver.
Be sure to NOT touch the metal part of the screwdriver. I've done that and the board started smoking.. It was almost cool.
Just look at where your power connector goes from the front panel, and bridge thse with a screw driver. Don't leave it connected, just touch them, andyou'll be fine.
The problem was that I never connected the board to the 4 pin 12V ATX. Asus tech support was helpful.
Update: The problem was a bit obscured by my incompetence. After connecting the 12 ATX 4 pin connector, I found that my old CPU would boot to the bios but my Opteron 185 is gone. Anyway thanks to all. Hoping that AMD can replace this chip. It should be under warrantee. The pins are straight now and fit nicely in the socket. I cleaned the pins with solvent, they look nice under magnifying glass. Hope they don't get too picky.:rolleyes:
lol. don't worry man. I did that once. My first build wouldn't start up and I spent 3 days trying to figure it out. My friend came over and took a glance, pointed at the 4-pin, and called me retarded, haha. Have fun with the system. Hope you get your opty back :p
