3 beeps on startup! Help!
lexcruiser
I ran the Memtest benchmark program earlier tonite and system has not booted up since. On startup, theres 3 beeps and no video... Checked error beep codes and its saying that it means base 64K mem is bad. I tried re-seating all 4 of my dimms and right now, trying to boot up w/ just 1 chip in, still nothing, only 3 beeps.... Help!! :(
What bios are you using, is it an Award bios? Do you get one long beep and two short ones? If so it's a video error, try to reseat your graphics card.
Thanks for replying.. It's actually an AMI Bios. Weird thing is, it alternates between either 3 quick beeps or 4 quick beeps. The 4 beeps usually happen after clearing the CMOS and booting up, the 3 beeps happen every time I boot up after that. Still no boot up and no video.
I've tried re-seating memory, vid card and CPU. It *did* boot up OK a few times after clearing the CMOS but not anymore. I've already tried using brand new mem chips so I dont think its the RAM. I dont think its the vid card either since that worked on bootup a few times....
Right now, I'm guessing its the mobo since 3 or 4 beeps seem to indicate a possible mobo problem.
Any other suggestions before I go ahead and buy a new motherboard??
Thanks in advance!!
Know how it feels, RMA:ed my mobo (MSI K8N Neo2 Platinum) 2 weeks ago, haven't got a new one yet :(
It doesn't sound like a PSU problem, but you could always try with another PSU, if possible.
Are the fans running or do they just spin up for half a second?
Yea, this totally ruined my whole weekend. =T
The only problem is (and this part is my fault), I cracked one of the retainers on one of the dimm slots when I was trying all the diff RAM chips. The slot still works, but I don't think they'll take the board back seeing that its 'physically' damaged. :(
I'mma just have to suck it up and buy a brand new board. Its only 3 months old too.
All fans (2 case fans, HSF, and Vid card fan) are spinning, and power is also going to my USB devices. On the few times that it did boot up, everything seemed normal once I got into Windows... So it really doesn't sound like a PSU issue right?
Is it possible for a mobo to be bad but still 'work' right a few times out of 10? Its not booting into Windows at all anymore, but it did by clearing the CMOS a few times...
I'm just afraid that it might be something else and I'd be buying a brand new mobo for nothing. ARGH! :( :confused:
When i got my mobo it wouldn't always boot. Had to unplugg the powercord and then plugg it back for it to boot. When I got it to work it was rock stable. Then one day it wouldn't boot at all, fans just spinning up for half a second.
