p0intblank
- Jun 27, 2005
This is a post for a friend since he can't register:
I have a question about how to route my tubing for a water cooling setup I'll be doing. I'll be getting the Koolance Exos-2 and I'll be cooling my GPU, mobo, and CPU. Now, the cpu waterblock can be bought with 3/8" fittings or 1/4", and I'm wondering which setup would provide better cooling. With the 3/8" fitting I would have it go:
rad->cpu block->opening splitter->one to gpu, other to mobo->closing splitter->back to rad
Then with the cpu block that has 1/4" fittings I would have it go:
rad->opening splitter->one to cpu then to mobo, and the other just to the gpu->closing splitter->back to rad
I'm wondering which size fitting I should go with since the size of the cpu block fitting will change the setup, or if theres another better setup I didn't mention. Thanks.
If you want to talk to him directly, his AIM screen name is DevilTrigger529
