3.5mm to RCA adapter
Does anyone know where I can get a good quality 3.5mm to RCA adapter? Monoprice has some good shielded RCA cables, but their adapters are very thin or clunky.
An all in one cable works as well.
Thanks.
I just bought a load off ebay (UK) with gold plated connectors and Oxygen free copper.
About £4 per stereo pair.
They go by another name too, 3.5mm to Phono cable.
lol, i should really get some cables.. im using some cheap little 6 inch 3.5mm to rca then using component video cables to the sub and then some half decent rca cables to the monitors.. and all way to long for the small space im in :p
such a pain up here in Canada.. have to wait until Christmas break to head to florida to order from all the cool people sites :D
Are you sure you're Canadian? There's lots of great places to get cables, I never have a problem. Try your local independent stereo shop.
Monoprice is good for some things, but not audio cables. I find the cables that are provided 'in the box' tend to exceed the quality of Monoprice cables.
