What do you guys think of the Corsair Nautilus 500?
Ok, I'll back up my dumbass opinion.
If you plan on doing any serious overclocking, or cooling anything other than your cpu overclocked your going to need a bigger radiator.
This thing is the equivalent of buying a dell, and hoping to overclock it and upgrade it.....you cant really do anything if you decide to change your system a lot.....and it doesnt have upgradeability for the future.
But it's also very cheap and would be good for cooling a system with little oc's.....so do whatever you want, but if i were you i would at least get a 2x120mm radiator custom setup.
Yep. And it's external. And it's 150$. You could build a similar setup, for about 100$.
Actually, it would be hard to build a similar setup, as most commercial waterblocks are way better, but a bit more $$.
The problem is I'm using an SG03, so it's going to be hard to put a 2x120 radiator in there. That's why I looked at the Corsair.
Can a 1x120 handle a quadcore? I plan on swapping out the processor very soon.
Take a picture inside your case please?
Ill tell you what you can fit/where.
EDIT:
You can also use 2x 120mm rad in the same setup....my cousin has his comp setup that way and it works fine.
Really? A 2x120 can fit in the front panel? I'm impressed. I tried measuring it and through it wouldn't work.
Sweet. I'll keep that one in mind. I don't plan on WCing my GPU so this is what I've come up with so far.
2 Black Ice Pro 120s, d-tek fusion cpu block, and Laing DDC3.2 pump.
