3.5" bay ideas
phokur
I have a empty 3.5" bay slot in my shuttle. I don't really need a floppy anymore, and already have an external card reader. I saw a raid controller which would be awesome, but mounting it would take away a location for the second hard drive. Anybody seen any neat things that could take up that wasted space?
why not use it for another 320GB HD, does your shuttle support RAID0/1 ? maybe a 74GB raptor specifically for OS or gaming ?
Not a bad idea, not sure how much further I want to push the psu though. I remember seeing a little valueables drawer once, wish I could find that again. Did find this, though it seems like a bad idea to keep drinks that close to the tower... :p
Too be honest a temperature gauge is what I really need, but they don't seem to make just a simple 3.5" temperature gauge. Always with a fan controller which I don't need because I have a shuttle. :(
if you want a temperature gauge, then go to 411 Tech Systems and buy and LCD, mount it in a 3.5" drive bezel and do it that way. It's simple AND it's DIY.
awesome replies! what is the interface with these things? :confused:
edit: ah just saw usb for crystalfontz, any idea if it'll work on 64bit machines?
CrystalFontz are just USB/RS232 interfaces (with software) for standard LCDs driven by Hitachi HD44780 series controllers. If you want, you can also buy the LCDs by themselves and drive them via LPT and bit bang the display.
ICY DOCK makes a nice 3.5" drive bay unit that has a removable 2.5" hard drive enclosure.
