- Jun 3, 2003
I built my mom a computer with a 3.4 C in an antec overture case.
Case linky: http://www.newegg.com/app/ViewProdu...1-129-142&catalog=7&manufactory=BROWSE&depa=0
I'm running this thing completely at stock. Heck, I can't even turn any of the game acceleration features off auto without it locking even before the POST. That's probably the memory's fault, but that's not the question at hand here. The thing is that this thing is running much, much, much too hot. The CPU under load reaches like 67 C, and the ambient case temp as reported by the IC7-G is around 38 C. I suspect that the problem may be the CPU cooler. It's the stock intel cooler, and I don't know if this is a new design or not but it's got a set of fins coming off four central alluminum arms, and these arms are somehow connected to a copper core. One reason I am suspecting it is that the copper core stick out from the rest of the heatsink, meaning that it is really the only thing contacting the CPU. I'm no physics expert, but less surface area = less heat dissipation.
Now, as you can see from the pictures, the Overture isn't exactly a case optimized for airflow. There is a power supply fan you can't see in the pictures, but with all the cables in that are I doubt much is reaching the rest of the case. My question to you guys is whether you think getting a Zalman CPNS7000 would help drive down both case and CPU temps. I might just get one regardless just because I'm sick of hearing the hairdryer noise of the fan.
