3/4 Pin Fan question.
No matter what connectors a fan has, you can always get an adaptor. You're better off picking a fan you like based on air flow and noise, and then having to buy an adapter if you need to.
It's either or. Can use the molex, or use the 3 pin. I bought a bunch of the Yate Loon fans when they were on sale at jab-tech, and they came with the 3 and 4 pin connectors, I just removed the wires for the molex connectors all together, so all they have is the 3 pin.
