3.336Ghz vs 3.2Ghz
keldegar
Do you guys think its worth running 24/7 @ 3.336Ghz vs. 3.2Ghz?
According to Sandra memory bench, I get lower performance at the higher DDR2-834 than at DDR2-800.
Also I can see the temp scale up pretty quickly as soon as I hit over 3.2Ghz. I've found 3.336Ghz to be my max Orthos overnight stable (12+hr). Anything higher (as in 1 mhz fsb) and Orthos fails the blend benchmark right away.
I have the Corsair DDR2-675 kit so it's probably maxing out (most voltage i can give it is 2.1V)
It runs idle @ 3.2ghz = 38C, idle @ 3.336ghz = 43C
It runs load @ 3.2ghz = 45C, load @ 3.336ghz = 51C
What do you guys think? Worth the 133Mhz?
i would say no....you already have it at 3.2ghz, and the extra temperature added kinda turns me off, i mean you add 100mhz but add almost 6 extra degrees Celsius?.
it's worth running as high as your system can be rock solid. heat be damned. if heat is causing problems, you will not be stable. if you are stable, then there's no heat related problem and you're A-okay.
don't just use sandra to measure your performance though. it's likely that a fsb strapping issue is loosening sub timings once you cross 400 fsb (i had this issue on the 965p platform as well) and that's why your memory performance is a little lower. but generally it's worth a small memory hit to get your CPU going as fast as possible!
i think the 133 megahertz is worth it. you can't be 1337 without it ;)
i'm actually thinking I have a pretty good chip and getting better RAM so I can hit even higher speeds. how about that? :D
i'm 3.336Ghz stable @ 1.320V idle, 1.264V load (1.4V in bios, jesus Asus is that enough vdroop?)
The arctic cooler seems to be doing well keeping my CPU cool. RAM seems to have dropped since I built my system (early Dec) so maybe now's the time to buy faster RAM.. (I got my Corsair ddr2-675 for $199 back then, but ddr2-800 ram was about $260-280 for 2gb)
I thought of something else -- Does anyone know if there's a clockgen for the Asus P5B-E?
That way I can test my CPU's max without having to buy the new RAM first.
clockgen should rise ram too..
Perhaps look into vdimm mods. I'm willing to bet if you compare the ds3 pencil mod with the p5b board, a similar approach is possible. I was going to venture into testing it out but my p5b is a newer revision that supports vdimm up to 2.45v. Definitely, 400fsb is better than the other. The lower strap will help you with overall speeds as you've witnessed. If you do venture into the vdimm mod though, you'd want to see if you can aim for 466fsb or so, with a lower multi I'd imagine, since that's where you'd get thrown into the same nb speeds again as 400fsb with 1066 strap.
what if I do 400FSB and use a clockgen to push to 417FSB? Wouldn't that give the best performance?
