3.2Ghz Temps?
OopsX
Guys,
I just finished installing the new parts:
Intel P4 3.2C (on stock cooling...boxed version)
Abit IS7-G
1Gig Corsair TWINX1024-4000PT
Lian Li PC-65B
Vantec Stealth 520Watt Power Supply
ATI Radeon 9800 Pro 128Mb
Right now my idle tempurature is 40 degrees. I haven't been able to test under load yet because I had to re-format the disk and start from scratch. I am in the process of downloading Counterstrike Source so that should be able to test the system pretty good.
What kind of tempurates are you guys running with a similar setup?
BTW if anyone has a link to the best drivers for the Radeon 9800pro I would appreciate it. I had the OMEGA drivers before the format, and I can't remeber the link. :(
Thanks!
Oops
I have my 3.2 OC'd to 3.71 and right now, running stock with Antec Silver 5, and lapped stock heatsink, and case open, I am at 36c according to MBM 5. Before I sanded down my heatsink and was used the supplied heat paste with my case closed, I was around 46 idle. Your temps are fine.
Catalyst link: http://downloads.guru3d.com/download.php?id=18
For benchmarking and best game performance, beta 8.07 is best
