3.2E DO rocks!
bubblethumper
That is all.
I'm still about two weeks away from getting my mobo back from bitchbreaker, so can't really have any fun just yet.
3.2E DO got in today on the Vapo, and I'm really excited! Stock voltage took me all the way to 4150ghz (259fsb wall). I am amazed at this chip!
My 3.2E CO doesn't OC nearly as well without some voltage help.
Hmm.... could this be.... a 5ghz possibility? :)
Now, I just need this prescott to outclock my 3.4C (which goes to 4.4ghz thanks to the higher multi and some high voltage) and life will be good.
Exactly what voltages are you IC7-Max3 guys modding on the boards?
Are you possibly fixing the thermal resistors?
Voltage: Northbridge, AGP, memory, vcore
Northbridge and AGP will help with my 260fsb limit (your FSB limit will vary depending on board revision).
The memory mod helps with voltage instability (known issue with the max3)
And vcore for droop (but not really needed)
