Sc4freak said:A 2.8e should NOT be getting such high temps... My estimate would be mid 40's for idle and low 60's load. Unless its 40C room temperature or something.
Slammin said:Weird. I'm running my 3.0E@3.7 with 1.48 vcore and idle at 42 and max under load never above 60c. I really do think my case cooling has everything to do with this though because before I cut a hole and added a 120mm side fan, even my vid card had problems due to the extra heat the 3.0E added to my case.
