3.2c @4ghz -SP94
I know It's not the first by along way but I was quite chuffed so I thought I'd post it
AI7 3.2c @ 1.725v (1.66-1.68 actual ) Did half an hour of Prime95 and couple of runs of 3dmark01 ,Hexus pifast Sisoft etc...then I chickened out and put it back to day to day (3.72Ghz 1.575v actual) I did have a question too - Is the difference between what I set In the bios and actual load voltages caused by my PSU (460w Enermax) or the MB ?The 12v lines solid at 12.33 the 5v also good but my 3.3v jumps between 3.33 -3.48 could that cause any issuse ? Temps are 37 at idle 49 full load ( at 4Ghz room temp about 22c) ;) excuse the self pleasuring nature of the thread just thought someone [H]ere might give a shit more than my non-overclocking m8's
Your PSU voltages are fine. The voltage drop under load is caused by your motherboard, but it is basically unavoidable in today's times.
i have had 2 AI7 boards and the first undervolted my vcore by about .03 my latest is undervolting .01 so yes its your MB dont be aftraid to go as high as 1.7 in your bios as long as your temps are fine
