Originally posted by am71ap1
Remember that i will be also going from 533 MHz FSB to 800!
Now, is it still not worth it?
Originally posted by rive22
EarthwormJim,
Hey dude, what vcore, vdimm, and ram timings are you using to get that overclock if you don't mind me asking? I can't seem to get stable over 2.64I think maybe it's my board because it doesn't support bus speed over 533. I'd still like to try more though. Otherwise, you think that could be my problem? Aside from getting new and faster ram.
lol, you want me to add that sig virus to my sig man?
Cool, thanks dude. I had a whole reply typed up last night for this, took me like 20 minutes and then my computer just rebooted all by itself!!! LOL dangit! You're right, I'm sure it's all 3, the ram, mobo, and the proc, I could have better of each and be better off, but looking for the weakest link, I think it just might be may ram like you say. I was a noob last year when I put my computer together so I did what most noobs would do, without thinking it mattered I went ahead and bought generic ram!!Do steppings really matter? Anyways if they do I have a C1 stepping which every seemed to think overclocked good for P4B's. I had to increase my vcore a tad to get it above 2.9ghz, it's at around 1.625 (varies a little though 1.62-1.65). My vdimm is at 2.7, but I had to go with less aggressive timings to get my ddr-333 to almost 400mhz. Timings are 2.5/3/3/8. I would have prefered to run my CPU at 3.15ghz (166mhz FSB) with a 1:1 ratio on my ram (then I could use way tighter times), but the CPU failed prime in two seconds. It could be your ram, probably the best way to varify this is to go with looser timings when overclocking. It could also be either your motherboard or CPU, kind of hard to tell which it could be though.
