2ndedBarneyGumble said:no, you should upgrade to quad sli you loser.
arthur_tuxedo said:If I can get by with my 9800 Pro, you can get by with probably 10 times the graphics processing power.![]()
MatDef said:Personally, I think you're ok. I have also have dual gt's, and a running at 1280x1024 I can still crank the newest games up to their highest settings. Of course, they can't really cope with 1920x1200, so I'm upgrading to a x1950xtx. If you're on a budget, it's probably better to just wait for awhile.
I'm not as picky as most. I like 1280 x 960 with at least medium settings and no AA or AF, but I can stand 1024 x 768 with the same. I can't stand low settings or 800 x 600.MrGuvernment said:And what do you consider "getting by" with a 9800 PRO, i played CS:S on my uncles comp with a 9800PRO and i hated it, i stopped playing with in minutes...
2 7800gt's>1 7900gtEndurancevm said:My 7900GTO played everything(less COD2) at 4xSSAA and 16xAF @ 1680x1050. The http://hardforum.com/showthread.php?t=1115565
2x7800gts, good enoughX1950 i got to replace the dead GTO will do more of the same...
If you play 1280x1024, you have no reason to upgrade now, but if you are playing higher than that, ie 1600x1200 or 1680x1050, then you could always get a 7900GT which would run all games at fast speeds with good eye candy.
Not too sure about that. I think it's about equal(7900GTX has much higher speeds and also 4 more pipelines).Dark Prodigy said:
