5870 over 2x 5770s, but i'd seriously consider a 5850 now, and then add another when they hit $150 down the road.
what about cards that have two GPUs? Do those scale badly too?
i thot i read somewhere the 5970 was basially 2 5770s put together.
No its 2 5850's
Wrong chief. It's two 5870s downclocked to 5850 speeds. It has all 1600 shader cores per GPU enabled.
So basically 2 5850's with all 1600 SP enabled.
So I was somewhat right
If that makes you fell better, then yes, you get partial credit.![]()
