JulesBravo
- Nov 28, 2003
I'm building a new rig and I'm wondering what's better for the money. 2 NVIDIA 7900 GTs in SLI or a single 7900 GTX or perhaps something else?
yacoub said:7900GTX means no need to get an SLI board if you don't have one. It also has 512MB. I don't think having two 256MB cards bumps actual texture memory to 512MB in SLI, does it? Just each card has 256MB still, not 512MB pooled, right?
valve1138 said:I'd get one GTX like I did. So you can do GTX SLI later one without having to ditch 2 cards somehow.
TekSomniaK said:Well there's a difference between spending 600 and at least 1000 dollars bud. Now the reviews are showing SLI'd 7900gts mop the floor with a single 7900gtx anywhere from like 10-30fps. Don't kill the messenger on this one.
I'm always a big advocate of getting the "second best" hardware when upgrading. You tend to save about half an only lose about 10-20% performance, if that. I think you'd be pretty durn happy with a gt. But hey, if you've got the money and the desire its always nice to know you have the best.JulesBravo said:Would I be better off buying the 7900 GT instead of the GTX and spending the other money somewhere else like better RAM or upgrade the 3.0 Pentium D I'm planning on to the 3.2?
no two 7900GT's would blow a 7900GTX out of the water, I ran two 7800GT's and got 10,000 3dmarks in 05 with no oc, a 7800GTX only got 8200 3dmarks that should give u an ideaJulesBravo said:Everything I've seen says buying a single GTX is cheaper than buying two GTs, is the performance of a single GTX the same as two GTs?
KompressorV12 said:no two 7900GT's would blow a 7900GTX out of the water, I ran two 7800GT's and got 10,000 3dmarks in 05 with no oc, a 7800GTX only got 8200 3dmarks that should give u an idea
