Syphon Filter
- Dec 19, 2003
Hi Guys,
I've just put the system in my sig together. For the most part everything went pretty smoothly. The build went without hitch and I've got my OS and a bunch of games etc. installed.
All my motherboard drivers are installed (Chipset, MEI & Audio), I'm running the latest WHQL nvidia drivers and Windows is fully updated too. There are no unknown devices showing in Device Manager. I have also upgraded the motherboard BIOS to the latest available from Asus (1102).
Everything seems fine.
However, when I select the "Maximise 3D Performance" option in the nvidia control panel and hit apply my screen goes black and then throws a BSOD. While it's doing this I can hear the Windows "ding-dunk" followed by a "ding-dong" as if hardware has been removed/installed.
After a reboot the nvidia control panel shows SLI as enabled What I don't know is how I can check that SLI is actually working, is there a utility or something I can use to see the utilisation of each card while gaming or something?
IIRC disabling SLI doesn't cause any issues, it just does it's thing (I can't remember the sequence of black-screen/sounds etc.) and seems fine.
Either way, I still need to be able to enable/disable SLI without invoking BSODs because, as I've been finding, some games support it while others don't!
In terms of power connections I have the following connected:
ATX - 24-Pin
CPU - 8-Pin & 4-Pin
Mobo - Molex, I think this is an Asus specific thing
780Ti - 6-Pin & 8-Pin (both connections on same modular output from PSU)
I have the Asus supplied SLI bridge installed (it's the only one I have) and everything is at "stock" (the SCs are factory OCd).
Does anyone have any ideas what might be causing this? This is my first multi-GPU machine so I'm learning as I go here, any help would be much appreciated.
Cheers,
sf.
ATX - 24-Pin
CPU - 8-Pin & 4-Pin
Cheers,
sf.
