2x 30-inch display stand?
mikeblas
[H]ard|DCer of the Month - May 2006
Can anyone recommend desktop stand that will hold two Dell 3007WFP displays? I'd prefer an arrangement with one display over the other, with both displays in landscape orientation.
ergotron doesn't seem to have one. Ergo in Demand has one, but I've never bought their products before.
I could use one of those for my 30 inch displays. Seems kind of pricy though.
Im not sure if I would want the one side by side or on top of each other. Too bad they dont make one that you had the option of doing it either way.
$250 for the mount from ergo in demand is not bad; it's 10% of what you paid for the two panels. Their website is pretty confusing, though, and I never heard of the company before today.
I get all my plasma mounts from Cheif Manufacturing, and it turns out they have a few monitor panel mounts, too. But none are up/down.
Later: Oh. The ergo on demand mounts are Chief Manufacturing mounts. The part numbers are the same! The vertical mount can't handle a monitor as high as the 30-inch Dell, so it's right out.
Not sure about vertical stacking of the 30" LCDs, but I have this mount here:
http://www.amazon.com/Ergotron-45-245-026-Side-by-Side/dp/B0036FQ23A/
It holds two 30" LCDs side by side easily without issues and the arms don't slump, even though the 30"ers are a tad overweight.
The vertical one here:
http://www.amazon.com/Ergotron-Lx-Dual-Stacking-Arm/dp/B0036RDOT8/
should be able to handle the weight easily since it uses the same arms, but I'm not sure if you can get enough height to stack two 30"s vertically.
Worst case scenario would be you would have to tilt the bottom screen slightly to stack
