2x 285
ryu4000
i rmaing my gtx 295 cause problems im having looking to get 2 285 but wanna make sure i be able to power them up my specs is
1x dvd burner
1x 750gb hdd
core i
4x fans
pc power and cooling 750watt
also im going get 1 ssc and a sc version of evga 285 would it matter much?
If one is clocked higher than the other, the higher clocked version will downclock itself to match the slower.
edit;
Actually the 750W might be a bit weak for the GTX 285 SLi. If it works, then you're going to be cutting it close.
I think you're looking at 800W to 850W minimum, typically.
I don't know how much your system is pulling at the wall right now but with my system specs
i7 920, 4x seagates, 2 gtx285 sli running crysis sucks about 500 watt at the wall when under full load (according to my PSU AND kill-a-watt_.
I have that exact same PSU and I grabbed my friends 280 along with my old one and never noticed a single issue or stability...
pc&p is an awsome brand some of the highest quality PSU's available. it'll eat anything you throw at it.
