Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Hey guys, I want to have 2x sapphire dual-x 280x+powercolor 7970 for a mining rig but not sure how much wattage I need for a PSU. Do I need a minimum of 1000w? What is a good budget PSU that I can get. I have a i7 920 but it is not OC'd
If this is also your main PC/gaming system (not overclocked) then I'd recommend getting a 1000w power supply like the new EVGA supernova's with 10yr warranty.
If its a dedicated mining system that isn't going to be used for any other purpose, a good 850w power supply, like Corsair, should be fine. You should be able to undervolt your CPU + GPU's for less power consumption while mining.
