2x 120mm Radiator
Probably the BIP II, but I'm not aware of the heights of all 2x120mm radiators.
DaCoOlNeSs said:
wow aren't you a detective.
dude you just made me spit coke all over my new monitor :eek:
p.s. talonz you need to get your sence of humor checked out, something seems to be wrong with it ;)
maybe it could be that sarcasm doesn't translate very well into 1's and 0's :eek:
ON TOPIC : I agree that the BIP is probably your best bet for a thin radiator.
If you've got a bit of time to waste you might want to check out a universal oil cooler or transmission cooler. These things tend to be around an inch thick, and come in all kinds of different sizes. I have the one listed here, and it actually performs better than my Bonneville heater core everyone loves for the dual 120mm fans. It is a bit wider than the heater core (almost exactly the width of my case, slightly smaller), but it has great flow and there's no need to JB weld any fittings on since it's all ready with 3/8" fittings. A quick search on ebay for "transmission cooler" turned up tons of different sizes and types, so look around.
good call
I'm liking the look of those transmission coolers. I'll have to remember those next time I do a WC system :)
I also noticed they come as thin as 3/4"
Yep.. things aren't going my way in life, shit happens.. I'll work on that sense of humor ;)
sorry to hear that bro, we have all been here, keep your chin up and I hope things work out for you :D
