2U rackmount server too loud for regular house use?
general
I have a chance to get a good older server (2u, 2x2.4 Xeon, Supermicro board, etc) for a good price. Will this be too loud to put in an office? Is there a way I could make it reasonable to use or am I better off buying a nice server case for it and moving the items over. Will there be any problems fitting the motherboard from the 2u case into the standard case? Any ideas?
I've never met a 1U or 2U that didn't sound like a jet engine. I'd move the parts into a new case. Check if the board is extended ATX, and the dimensions to make sure it's new home will accomodate. You will need a new power supply.
12 x 13 will fit in many cases, but not all. Usually the case manufacturer specifies the max size of the motherboard.
Yeah, I'm around servers all day and can tell you that because they use passive cooling on everything they rely on a large volume of air moving through the case to dissapate all the heat.
If you can, you would be better off switching to standard Intel heat sinks and fans to cool the procs. Just be sure you get a case with good ventilation. Two older Xeons will generate a ton of heat that will need to be exhasted out of that case quickly.
