2u build
sdadept
I've built a lot of computers in my day but I've never built a Xu system. From those of you who have done this before, are there any 'gotchas' that I need to know about before I embark on this?
Basically I'm wanting to build out a 2u xeon server. All the places I see where I can buy them are charging huge premiums for them already built so I want to do one myself.
Any advice?
2u aren't nearly as bad as 1u.
Most 2u cases take standard 80mm fans, and intel's standard xeon heatsinks will fit if you use the side fan mounts. Drive mounting is normal.
You can either get a case with a 2u power supply included, or one that takes a standard ATX power supply. Just be away that you can't have a bottom fan style power supply in one of those cases.
Are you planning on having any cards? If so, you'll need a riser
great info, thanks.
I don't have any cards that I plan to add (I'm going to try and buy a board that has all the SATAII stuff I need built in).
On the motherboard side of this. Do I need to buy a motherboard that is specifically designed for 2u?
Also, what about heat sink. Should I start looking for a 2u xeon heatsink?
2u heatsink I recommend for xeons is the one from supermicro. Just sold two pair of them in FS/T, actually :(
could you be more specific on which xeon heatsink you recommend for 2u? Which supermirco model?
FAN-042-CF or FAN-042-CU
This is of course assuming that you're building a socket 604/603
No idea on who makes a good 771 heatsink
after looking around a bit, I think I'm going to build this out as an AM2 brisbane system (it's a low end failover server) instead of a low end xeon system. So I'm going to have to hunt down some brisbane 2u heat sinks.
