2P won't DL WU
knopflerbruce
I got two rigs folding, they seem to get work units - the last one, however, doesn't. Attempt #13 to get work failed, and no other work to do. This started about 24h ago.
Parameters are -smp 24 -bigadv. Tried -bigbeta, but didn't help. I'm using Ubuntu 10.04 on this particular setup, could that be the reason?
It IS connected to the internets, tested that as well. No issues opening webpages.
Please download and run fahdiag:
Code:
cd $HOME
rm -f fahdiag
wget https://raw.github.com/team33/fahdiag/released/fahdiag
chmod +x fahdiag
./fahdiag
and paste the output, please.
EDIT: the suspicion is that Langouste is somehow involved
If it isn't -- see also http://foldingforum.org/viewtopic.php?f=18&t=23849
Deleting the files worked, thanks.
I can't believe I didn't try that before posting, it's probably the first thing you should do when you face issues like this :p got a P8102 instantly.
