Heres the deal. I got a spanky brand new DVD DL Burner installed into my RIG.
First time round XP went to work install the drivers no problems, I even got it to burn a 4.7GB DVD in 3mins So I think COOL all is well
But just when I thought it was all over. The next time I booted up XP said it found new hardware again (the burner) as it started to install the 2nd Secondary IDE Channel is stops and tells me that the drivers its using to install the 2nd Secondary IDE Channel aren't ment for WinXP
Now the funny thing is its just trying to install XP's default IDE control driver.
XP still sees the Burner (sometimes) but now every time windows starts it finds the 2nd Secondary IDE Channel and trys to install it but with the same result.
I have tryed switching the drive to the IDE channel 1 but the same thing happens with the drive on IDE Chennel 2
I'm Running 3 IDE Drives and 2 SATA Drives.
IDE:
Lite-on DVD-ROM: IDE 1 master
Lite-on CDRW: IDE 1 Slave
Lite-on DVD-R/RW DL: IDE 2 Master
SATA:
Matrox 160Gb 8mb: SATA 1
Seagate 200Gb 8mb: SATA 2
I don't think it's because I have so many drives as my MOBO can also hook up another 4 SATA Drives.
Anyone got any ideas, on how to fix it?
IDE:
SATA:
