2nd SATA 6.0 drive problem
BlizzofOZ
Just getting my Sandy Bridge up and running.
mobo: Asus P8P67 Deluxe
I successfully got Win7 installed, of which I never used before (coming from XP), and I see my main C: drive which has the OS installed. In Windows Explorer, I only see my C: and blu ray drive... I don't see my 1TB 6.0 SATA drive.
Upon boot up, in the posting I see both of my SATA hard drives listed. In UEFI, I see that they both are there also. But in Win7, I only see on hard drive.
I have no idea why I'm not seeing the other drive... any ideas?
Again, not proficient in Win7, so...
I would appreciate any help... thanks!
Did you install all the mobo drivers/update Windows 7? You could be missing some hotfix or something.
Is it plugged into the Intel ports or the Marvell ports?
I installed all drivers that came on Asus's CD... including the Marvell SATA 6G driver. I don't see an Intel SATA 6G driver though.
C: (which I see) is on the Marvell port, top one.
Other drive (which I don't see) is also on the Marvell port, bottom one (closet to mobo).
On the mobo, I see them marked SATA 6g E1 and E2... and assumed E1 is the top and E2 is the bottom.
Also found Device Manager and both hard drives are listed... I just don't see the 1TB drive in windows explorer.
... and thanks for the quick response!
I'd try moving it off the Marvel port and try it on the Intel ones. There have been a lot of posts about people have problems with certain drives and certain ports with these boards. I got my C300 to work on the Intel Sata 6 ports with no trouble, but other people have been having a hell of time. Best option is to try the other ports to figure out if it is a port issue or a software issue.
What bios? What board revision?
mmm... ok, I'll give that a try then.
The mobo version is 1502, but I think I thought I'd seen 1503... but I could be wrong.
I used Asus's Suite to check for updates and nothing came back.
This is the newest revision... was that B3?
Go into system and security > administrative tools >Computer Management...should show up there...you probable need to format and set the partition active
2nd'd
You need to go into Computer Management and Initialize the Drive, then format.
