2nd gpu client "Calling fah_main args:14 usage=100"
zero2dash
Just noticed this in the 2nd gpu client...anything to fret over/worry about?
Should I change the config on the gpu clients to cpu usage 50 for each? (they're default...cpu usage 100 on both)
Both gpu clients are working though; right now gpu 1 is running a GPU2 NV MT 1888pt WU, gpu 2 is doing a GPUv2 Gromacs 787pt WU. (Guess gpu2 just hasn't grabbed a GPU2 NV MT core WU yet)
TIA
I noticed that in my client that is down now, not sure how I didn't see that, I've no clue what it means
I do know that that client instant EUEs now on any WU it gets, and the problem persists even after a clean reinstall
Posted via [H] Mobile Device
people were saying there was a new core downloaded.. makes me wonder if thats the problem..
I hope it's that simple, pisses me off that I'm down 8k and I didn't even do anything this time
Ideas for a fix?
Well mine are still chugging along (both gpu clients - going on 6-7 hrs) so I guess everything is ok. [scratches head] Technically I would think since I'm running the cpu client anyway I'm surprised the gpu client (even a single instance) doesn't report 100% cpu usage, but whatever. ;) Currently gpu 2 is doing the larger NV MT WU and gpu 1 is doing the smaller gpu Gromacs one so I guess the core changes off and on based on whatever WU the card gets.
Sorry to hear about your problems Vaulter. :(
