This. Instead of being screwed when either D5 fails, only be screwed if BOTH D5s fail. You might be able to reduce the pump speeds and enjoy reduced noise with similar or better flow rates.I would put the two pumps in serial as a single loop. It will boost flow rates somewhat, but the primary benefit will be redundancy.
