2k Gaming Rig, Advice?
VandyRob
Okay I think im about ready to buy this system.
From Newegg.com
Case: Lian Li Pc-61, $100
Motherboard: GIGABYTE GA-P35-DS3R, $130
RAM: Patriot eXtreme Performance 4GB(2 x 2GB) PC2 6400, $245
Hard-Drive: Seagate Barracuda 7200 rpm 500 gig 16mb cache, $120
Lcd Monitor: SAMSUNG 216BW Black-Silver 21.6", $250
OS: Vista 64-bit, $115
Frome Securemart.com
PSU: Corsair 520W, $100
From Zipzoomfly.com
Video Card: 8800 Ultra, $560
CPU: q6600 retail, $300
After Mail in Rebates (those bastards) total $1920, shipping ~$40
Few questions:
Will retail cooling be good enough for moderate overclocking, or is it worth spending extra on cooling?
Good RAM choice?
Any other mid towers you can recommend?
Feel like I forgot something, ive got keyboard, mouse, speakers, headset... maybe that's it. Anyway, tell me what you think. Thanks guys.
Definitely worth spending (even $50-60) on cooling. People that OC with the stock HSF must like seeing 70C under load...
RAM is fine but you should be able to find some nice DDR2-800 cheaper than that.
I love my P180B, but cases are 9/10ths personal preference. Just find something you like, ideally with 2+ 120mm fans to keep things cool and quiet, and you should be good. Remember the Ultra is pretty big, so nothing too small.
I'll second an Antec P180.
I'd definitely invest in a heatsink--retail ones are usually iffy.
I'd probably get a bigger PSU.
I also (personally) think the money spent on a 8800 Ultra is a waste compared to the 8800 GTX.
It's $50 more on average now. The revised cooler running core, slightly lower power draw, and better overclocking potential with faster memory onboard is worth that, I think. I wish I'd waited and got one, personally.
get aftermaket HSF even if not OCing.
If you're not OC'ing, theres really no point in buying an aftermarket HSF unless you want absolute silence; in which case, the Scythe Ninja would be best (without fan - for absolute silence). Its not like Intel sells these CPUs with less than adequate coolers... that would be just plain stupid.
This is all I've seen you post in recent memory. Just a little odd.
I tend to miss stuff when I read here for some reason. I keep stating something redundant so i just edit it out. I actually do post real content..normally.
Here I'll explain:
The OP posted that they were getting the Corsair PSU from Securemart for 100 and I saw it at buy.com for 80 AR. However, on checking securemart, it seems to be 86 dollars, not 100 so I edited it out because nobody except me would care about six bucks. Mind you, this was after posting the link, so I decided it was redundant and edited it back.
