I have a new site needing PoE for their VoIP system as well as the usual LAN config.
I haven't used Cisco PoE switches for a good couple of years now and was wondering what you think of the 2960-48PST-S?
I will probably need PoE up to around 50 Meters and will be using PoE on most of the 48 ports over CAT5e
100Mbps with 1Gbps upload is fine so these switches do seem to tick all the boxes but I’m not sure if there are better options?
