Waterhazard
- Sep 23, 2005
My new HIS 290x reference video card does not output video via the DisplayPort, but it does output audio over the built in speakers on my Asus VG248. Here is a cut and paste from my support ticket I thought I would run past you all:
DisplayPort does not output video, but does output audio. HDMI and DVI both work properly. Installed a second monitor via HDMI (Asus VS248-also works via DVI as noted before): The following errors are present upon boot regarding the other DisplayPort attached monitor: "DisplayPort Link Failure" ; "DisplayPort Lower Setting Applied"
Installed an older DisplayPort capable video card and confirmed that the monitor and cable are working properly.
Reverted to 3 previous motherboard bios versions with no effect.
Reverted to bundled catalyst video drivers with no effect.
Any ideas other than defective card?
