goto jonnyguru's website and read his forum. There's a thread specific to 8-pin pci-e connector PSUs.Ok, has anyone seen that you need an 8 pin PCI-E power connector to overclock this card? How do I find power supplies that do, I want to be ready for Crossfire and I hear this card is a power hog, any recommendations?
Check the specs? It should include what kind of connectors it has.![]()
I thought that was what I was trying to do here, "start a tread specific to 8-pin pci-e connector PSU's"goto jonnyguru's website and read his forum. There's a thread specific to 8-pin pci-e connector PSUs.
Silverstone
STRIDER SERIES
- ST85F - Single PCIe 8pin
- ST1000 - Dual PCIe 8pin
OLYMPIA SERIES
- OP650 - Single PCIe 8pin
- OP750 - Single PCIe 8pin
- OP850 - Dual PCIe 8pin
- OP1000 - Dual PCIe 8pin
- OP1200 - Dual PCIe 8pin
DECATHLON SERIES
- DA650 - Single PCIe 8pin
- DA750 - Single PCIe 8pin
- DA850 - Dual PCIe 8pin
- DA1200 - Dual PCIe 8pin
Thermaltake
ToughPower SERIES
- W0155 - Three PCIe 8pin (1000w)
- W0156 - Three PCIe 8pin (1200w)
And the 'Cable Management' editions of the ToughPower
- W0132RU - Three PCIe 8pin (1000w)
- W0133RU - Three PCIe 8pin (1200w)
OCZ
OCZ has some, as they were used in many reviews yesterday, but I'd be damned if I found any info explicitly stating which PSU's do and don't carry the 8pin.
Enermax
Enermax has updated a few of their PSU's, but you'll have to give them a call or wait for them to update their website.
Corsair
Is going to be the same as above, as per the websites. They do have a product, which complies, I believe, but have yet to fully disclose details.
For a more complete list, be sure to check out Johnny Guru's.
You'll also need to be careful as to which companies are offering the 'correct' PCIe 8pin connector, as per the PCI-SIG specification. For more info see:
- http://www.jonnyguru.com/forums/showthread.php?t=1220
- http://jonnyguru.com/images/8-pin_connector.pdf
