- Sep 24, 2007
What is better?
What is better?
the only 2900pro cards on newegg are 256bit but they did have a 512bit not too long ago though. I agree the op should just forget about the power hungry 2900 and go for a 3870 or maybe even a 3850 with 512mb.I was unaware that there was a HD 2900 Pro with a 256 bit memory path.
The HD 2900 Pro is basically a "failed" HD 2900 XT, which means it has the exact same features as the XT (including the 512 bit memory interface), but at lower frequencies.
To answer your question directly, there's not a whole lot of difference. At higher resolutions, you may notice a couple of frames difference, favoring th card with a 512 bit memory interface, but that's it. R600 is just not powerful enough for that much memory bandwidth...
Also, if you really want ATI, you should forget about the HD 2900 Pro. You should be looking at a HD 3870, which is basically a 55 nm HD 2900 XT, with a 256 bit memory interface and a few more features. It consumes less power, is usually a bit faster and is cheaper, than a full blown HD 2900 XT.
