After playing around with my 290 for afew weeks I really don't think the card is throttling because of heat like most think. it's more to do with gpu load then anything I have recorded so far no matter what cooler is on the card.
Here is a Valley 1.0 run with the target set to 90c and fan speed set to 100% @stock clocks... if the gpu load drops off well so does the core clock and I let it run 2 loops before starting benchmark to get temp up.
2013-12-01 11:40:54 , 947.0 clock , 1250.0 memory , 89.0 temp , 46 fan , 2411 fan speed , 98 gpu load , 0 , 1110 , 11.75 , 1.141 , 1.000 , 15.1 , 117.0 , 165.3 , 147.5 , 56 vrm 1 temp , 74 vrm 2 temp ,
2013-12-01 11:40:55 , 947.0 clock , 1250.0 , 89.0 temp, 46 , 2412 , 98 gpu load , 0 , 1110 , 11.75 , 1.133 , 1.000 , 14.1 , 124.0 , 159.8 , 158.0 , 56 , 74 ,
2013-12-01 11:40:56 , 947.0 clock , 1250.0 , 89.0 temp, 46 , 2414 , 98 gpu load , 0 , 1110 , 11.75 , 1.141 , 1.000 , 14.8 , 141.5 , 200.3 , 158.0 , 56 , 74 ,
2013-12-01 11:40:57 , 928.3 clock , 1250.0 , 88.0 temp , 46 , 2414 , 82 gpu load , 0 , 1133 , 11.75 , 1.141 , 1.000 , 14.8 , 130.5 , 188.5 , 153.3 , 56 , 74 ,
2013-12-01 11:40:58 , 947.0 clock , 1250.0 , 89.0 temp , 46 , 2413 , 98 gpu load , 0 , 1116 , 11.75 , 1.141 , 1.000 , 16.4 , 132.0 , 186.3 , 150.8 , 56 , 74 ,
2013-12-01 11:40:59 , 947.0 clock , 1250.0 , 89.0 temp , 46 , 2413 , 98 gpu load , 0 , 1100 , 11.75 , 1.141 , 1.000 , 15.3 , 134.0 , 180.8 , 149.5 , 56 , 74 ,
2013-12-01 11:41:00 , 947.0 clock , 1250.0 , 89.0 temp , 46 , 2414 , 97 gpu load
[/URL][/IMG]
