2800+ Barton @ 2.4 GHz
Wenty
I just installed my Koolance EXOS AI and boy does it work great. I'm running my Barton at 2.4GHz and the temp stays at 40-47C with cooling fans on low. :D
how much it cost you total.. blue tubing increases my interest.. i was thinking of getting si-97 and nice 92 mm fan but hmm...
what voltage as well..
$250.00 total.. both cooler and heat sink at New egg.You need to get the CPU-300-H06 heat sink separate.
Voltage?On the clocking is 200 x 12.0 @1.775 volts
meh! 40-47C at 1.775 volts!? my current cooling at same voltage does around 38-41C (thats measuring the heat sink... i somehow find it hard to belive the diode temp.. wich says the temp is 80-104F[idle vs load]) on a slk-800 with a 80 mm fan setup to be silent
My diode is 105F at idle. If it stays below 60C on load I'm happy with it and the fans are at low speed right now. I could make them on high but I don't need to. So the numbers that I show now could even go lower yet. Just to let you know. :)
no improvement for me.. i go for quiet not preformance.. if i turned up the enermax i got on my slk-800 or put a tornado i could probably do 2.8 ghtz
What are ambient temps?
That's very important when you're determining how a cooling system performs...
Lots of people just post temps, sure I can get those with a stock heatsink too if its -30 in the room.
bah, i have a 2800 barton in another system thats at 2.5Ghz 1.85v.
cooling, thermalright slk900a w/ 92mm vantec tornado. fan at 7v, load 54c/ fan at 12v, load 48 - 49c
