28" / 700mm depth wall mount racks?
cyclone3d
I need an enclosed 28" depth wall mount rack, 9U is preferred.
I would also really like the side panels to be removable.
This is for holding 2 switches and a 48 port patch panel for my house.
I've only been able to find 2 different ones so far:
https://questmanufacturing.net/product/extended-depth-mount-enclosure-removable-panels/
WM2019-09-02D
https://americantechsupply.com/product/wm2019-09-02d-quest/ ($355 + expensive shipping) - sides removable but doesn't swing out.
https://www.amazon.com/Tecmojo-Enterprise-Grade-Swing-Out-27-6inch-Equipment/dp/B0GX12ZN61/
$399.90 shipped. - sides not removable but it swings out.
Going to have probably 2x QSFP28 DAC and probably 12x 10Gb copper ethernet cables going from the server rack to the wall mount rack.
Anybody know of any others?
One of the reasons it's hard to find something like this is that being 28" it puts a lot of strain on the wall. You're actually better off with 'vertical wall mounting' the switch and patch panel using 1/2U mounts like these: https://sourceit.com.sg/products/st...-19in-vertical-wall-mount-patch-panel-bracket
You can even do this with the servers and other things as well as long as you pay attention to the airflow. It's what I plan to do for an Avaya 96-port switch I have for my parent's house.
I thought about that but need something enclosed as this will be in the utility room.
I'll see if I can find any vertical enclosed ones that aren't priced through the stratosphere.
I'm not even sure I would have room to mount stuff vertically and it is also a pain to work with stuff that is vertically mounted.
Got it. Then maybe two different 4U units mounted vertically so they're not out 28" from the wall? It's a challenge to keep things clean in a utility room, but maybe some sort of just generic 'cover' for stuff vertically mounted might work instead as you really just need it covered and the air filtered.
Problems with vertical mount.
1. Hard to see the lights on the switches.
2. I would need reverse flow switches so that the hot air goes up.
3. With the regular Ethernet ports on the switches pointing upwards, I then end up with needing to have something to hold them up and out of the way because they would be doing a 180 degree turn to go down into the server rack.
4. A pain to work with vertically mounted patch panels. It would need to be mounted higher than the switches.
Have you ever had to deal with a vertically mounted switch or patch panel?
It will make you want to jump off a cliff.
You end up having issues trying to see anything and also straining your neck when having to try to do things straight up and down.
I thought about / am thinking about buying a cheap adjustable open wall mounted rack and building a cabinet around it but it would take quite a while to design and build it plus with all the latches and hinges, grommets, 120v fans, wood, etc, it would end up being heavier and cost just about as much as buying a pre-made enclosed rack.
I guess I could do vertical mounts and mount them on the wall so the stuff was mounted sideways on the wall ... Still a huge pain to work with stuff like that though.
I ended up ordering the vevor 9U open frame rack that is adjustable from 23-40" in depth...
Yay, I get to mod it so it will be what I was looking for...
