270x low frames help!
robert125381
I am averaging about 50 fps on high presets this seems low to me as I am seeing benchmarks where people are getting much higher.
system specs
3570k
4gb 1833 mhz
h77 gigabyte mobo
gigabyte 270x
cx500 psu
I have tried adding more ram swapped the psu for a bigger one
added a h105 cooler completely re installed windows and all updates/drivers
I even rma'd the 3570k put the new one in today.
I have had it with this thing I slap this card into my bros pc
4770k stock
MSI mpower
RM750
8GB 1333mhz
and the card pulls like 90 FPS at the same exact settings (high preset)
using dx11 on both computers same resolution same everything....
If I cant figure this out I am close to selling it off for a ps4 frown.gif this is super frustrating and I
am begging for your help!
ok cool story, but what game?. what resolution?..
its in multiplayer?.. in single player it make almost no sense as its barely CPU stressful but in multiplayer your brother have a serious advantage over your setup, first the extra 4GB of RAM make a huge difference in battlefield 4 behavior but also the 4770K..
if you are testing in Multiplayer map you have to be sure to test several times and compare results later as each game will show a completely different behavior... it have to be same map same amount of people etc.. also, bf4 have a serious memory leak issue degrading performance overtime using mantle.. so you may try with Direct X to see how it respond to both machines..
