2700k @ 4.7Ghz cooled by H100 using 2 Cougar Vortex fans in Pull configuration (as intake). Board is P8Z68-V pro Gen3. Case is Antec P280.Looking to know if these temps are ok. Ambient room temps are about 20c (70c)
Stock:
Idle - 23, 23, 22, 21
Load - not tested
4.7Ghz
Idle - 33, 34 ,31, 31
Load (average) - 69,70,69,66
Load (max) - 74, 76, 75, 70
I used the following guide to overclock to 4.7Ghz:
http://www.youtube.com/watch?v=_fxXB5iiVS0
Cores stay at 4.7Ghz 24/7. OC settings can be found in video. Prime95 tested 24 hours without faults.
Trying to get a consensus if these temps are low, average or high. How odd that core 4 is always so much lower then the rest in all tests. Thx.
Stock:
Load - not tested
4.7Ghz
