27" HD Ready LCDTV - $797.00
cwt137
At Outpost.com
http://shop4.outpost.com/product/4090002?site=sa:Homepage:Spot3
They had a similar deal in-stores at Fry's this weekend.
Specs:
Features
27" 16:9 Cinema-Style Widescreen Aspect Ratio
> HDTV Display Ready (480i, 480p, 1080i, 720p)
> 750:1 High Contrast Ratio
> Wide XGA 1280 x 720 Resolution
> High Brightness 700 cd/m2
> Dual Built-in TV Tuner
> PIP & Picture Grid Views
> Digital 3D Comb Filter
> HDTV Progressive Scan
> 170 / 170 Degree Wide Viewing Angles
> VGA (DB15) & DVI-I PC Source Inputs
> Detachable 10W + 10W Surround Speakers w/ Sub-Woofer Output
SPECIFICATION
Panels
Active Screen Size (inches) 27" TFT LCD
Aspect Ratio 16:9
Brightness
700 cd/m2
Contrast 750:1
Pixel Resolution (H x V) 1280 x 720
Response Time 15 ms
Viewing Angle 170 (H) / 170 (V)
VIDEO
Progressive Scan
2:2 / 3:2 Pull Down Yes
Digital Picture Noise Reduction
Resolution Scan VGA, SVGA, XGA, SXGA
De-Interlace
Adjustable Color Temperature
VGA Auto Frequency Correction
TV Auto Frequency Tuning
AUDIO
Audio Output 10 Watt x 2 and Sub-Woofer
Speaker x 2 Detachable
HDTV Input Y/Pb/Pr x 1 (480p, 1080I, 720p)
Component Input Y/Cb/Cr x 1
Composite Video Input RCA x 1
S-Video Input 4-pin DIN x 1
Audio Input RCA L/R x 4
Mini - Stereo Jack x 1
DVI-Input DVI - I x 1
VGA Input DB15 x 1
TV System Support NTSC / PAL / SECAM
(Regional Specific)
TV Tuner Input TC / CATV RF x 1, NTSC Only
Earphone Output Mini - Stereo Jack x 1
Sub-Woofer Out RCA x 1
Service Port RS232 x 1
OTHER
Wall Mounted Type VESA 200, WM-10D / WM-20D
Horizontal Frequency 30 - 80 KHz
Vertical Frequency 50 - 80 KHz
PC Frequency Support 1280 x 1024 @ 75 Hz (Max)
Tuner Box Removable for ATSC Replacement
Power Consumption AC 150 Watts (Max)
Dimensions 21.8" (H) x 35" (W) x 8.8" (D) with Stand
19.5" (H) x 35" (W) x 4.2" (D) without Stand
Weight 48 lbs with Stand
38 lbs without Stand
Safety Certification CE, FCC, UL, CUL, CB, TUV
Energy Star
FUNCTION
PIP / Split Screen / POP 3 / POP12
Viewing Aspect Ratio 16:9, 4:3, Zoom
Clock / Alarm
Sleep Timer
V-Chip Parental Control
Close Caption
Language English, French, German, Italian, Spanish, Portuguese, Swedish, Simplified Chinese and Traditional Chinese
One bad thing is that the ad didn't say the brand and the picture of the item is too blury to see. I guess its a syntax or some other maker like that.
And to think, some people are waiting for the 24" Dell LCD... this is $200 cheaper!
15ms
700 cd/m2
170* Viewing Angle
Yeah, this thing is ready for football... or anything!
-SEAL
Looks like the Olivia made by syntax that I picked up from CompUSA on that midnite sale they had a while back for $699. Not a bad TV as I am using it in the small room now and produces a good enough picture on SD, haven't hooked up an HD reciever to it yet.
You forgot one key spec, it is only 1280x720 native res, whereas the Dell is 1920x1200. Big difference especially for PC use.
