Ok, so I read a lot of the guides.
System Specs:
Asus P8Z68-V Pro
Core i7 2600k
Hyper 212+
GTX460
8GB Gskill DDR3 1333
I decided to start at 4.5GHZ. The only setting I changed was the PLL Overvoltage. I disabled that. I ran Prime95 blend test, and it is still going at 12 hours.
Core 1 and 4 hit 68c, Core 2 hit 73c, and Core 3 hit 74c. The high temps were all hit at around 3:00 in the afternoon. Most of the time though, they were in the 55-65c range. The VID/Vcore is my question. Coretemp reports it at 1.37. Asus suite, CPUID, and HWMonitor all say 1.3-1.33 with it hitting 1.378 as a high on HWMonitor. It stays right around 1.32 for the majority of the time. It auto set to that as I'm in offset mode in the bios.
Is this VID fine? I don't really want to go any higher than 4.5GHZ right now. It seems like it is, but some people say 1.3 or 1.32 is the max you should go.
System Specs:
Asus P8Z68-V Pro
Core i7 2600k
Hyper 212+
GTX460
