pontiac4life
- Jul 25, 2012
I thought the "CPUVID" rating on CPU was Intel rated voltage based on what speeds the cpu is currently running at? I also read many of times that it can't be changed because it's just a suggested Vcore by intel programed into the chips, well mine will fluctuate, for example I'm at 4.5Ghz and 1.380v, when I look at my CPUVID with AIDA it will show 1.391v but if I change my voltage to 1.400v then I see a CPUVID of 1.421v with the same 4.5Ghz. How is that possible?
