L045B021 here. no idea what/where it came out of just yet (wasn't my ass, though)
sure batches aint 100 % percent sure . . . but they sure bring up you oc percentage
here's my L0LB705 24/7 low voltage passed linx 2 x 20 , if you wanna clock get a good batch
Man, I want that CPU of yours! May we trade and I will add some $$?
Seriously, where did you get your CPU?
Thanks dude .. cant sell love the temps ... how i got was watched all the first batches coming
Out from soon as i saw the L0LB705 batches i hit the button new egg bam i got lucky
I have the same as op and I got 5.05ghz watercooled at 1.45 volts but it wasn't Rick solid. I was afraid to psh the envelope at 1.5 in fear of blowing a chip for the sake of useless edge performance overclocking.
I just got mine, it's a L045B021, which turns up no Google search results. Anyone have this batch?
I'm installing the system over the weekend. Just wondering what kind of clocks you guys have been getting.
Is there one vendor with a good overclocking batch of cpu's in general right now.. or hit or miss no matter where? Even my batch number shows up in some db's as going as high as 5.2, but of course, who knows on the volts.. i'd like to get a cpu like a had before with 5.0 at 1.41 and 4.8 at 1.37 (got rid of first cpu as i thought i had a general issue that may have affected it, big mistake getting rid of it, new cpu cant go above 4.6ghz without excessive volts)
This didnt really match my experience..
IE: from the list:
L046B106
# 2212: 5100 MHz
# 2331: 5227 MHz
Mine would only safely go to 4.6ghz.
However, i'm not sure what is meant by #? What part of the UPC is that? serial number last 4? then in my case its 2585, which dont match what has been tested on this one (or reported)
remember on a non intel board you need the pll overvoltage fix via a bios update
Still all looks like a crap shoot luck of the draw to me. Every batch looked the same there for the most part.
I think things will change oce we get past the 'D2' stepping. Then... bring on the Ivy.
anyone have a L046b028 #3309 or 3389 (cant tell if 8 or 0), that can comment on how it does?
