Been running a sandybridge 2600k since about the time they were launched, and I believe I am starting to see the end of its capabilities....
Just added another 780ti sc and have been messing with surround displays at 3240x1920, and just not getting the performance out of the setup I think I should be.
Intermittent stuttering while benchmarking in SLI and poor framerates in newer games have got me taking a close look at my monitoring software, and I think I have figured out what the hell is going on.....
Using nvidia surround, all connected correctly @ 3240x1920 I was getting low gpu usage numbers and low power consumption, that all corresponded with bus usage hitting 90 to 99%
Spikes to 98%, framerate drops because of the pci-e 2.0 bandwidth bottleneck at that resolution, games play like crap because of the cards throttling to 50-60% power and usages all over the place.
So I decided to switch back to single monitor 1920x1080 gaming and instantly the bus usage went waaaaay back down to around 30-50%, frame rates shot through the roof and the stuttering is gone.
Durrr, I suppose.
But now, with both cards able to operate at capacity, my poor old 2600k @ 4.6 is loaded up at around 80-90 percent. Still games fine, but I am seeing the end of the road here, I think.
So i'm going to spend some cash on an upgrade... really got to liking the 3240x1920 surround, but that appears to be a little more than my rig can drive to my liking...
would like to go single monitor 1440, but I am wondering if I am going to run into pci-e 2.0 limitations and run out of juice on my cpu at the same time.
Do I have to stick it out at 1920x1080 for now and upgrade my mobo/cpu? Or can I treat myself to a 1440?
Opinions / thoughts wanted!
Durrr, I suppose.
